bufalobob
here is the new bender racing billet primary cover. it's anodized & comes w/ a bronze bushing in place of the crappy fibre bushing that yamaha supplies. the wider than stock bronze bushing gives more support to the primary cover & eliminates binding.
bob
bob
mrtwostroke
- Apr 24, 2003
- Sweden,Lulea
- Sweden
- Sidewinder MTX 240 Tune Sidewinder XTX 240 Tune MountainMax SL 153.
Got my today!!!!!
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
What did they cost.
bufalobob
kinger
Sure would be nice if they offered a better description on the web site.
I have no idea the benefit of this.
Is it lighter, how much? Will it impact the current weights you have? Is it better for racing or trail sleds? Does it help mpg?
bufalobob
kinger:
the clutch in the pics is off my 835 srx trail sled ( 194 h.p. @ dynotech ). the cover bushing has approx. 30% more surface contact area on the spider shaft than the stock cover. this along w/ the bronze bushing will not only be more durable but also improve shifting. i did not weigh it but it is definetly lighter. you can use any weights w/ this cover. as you can see in the picture my clutch has heel clickers in it.
bob
bob
dirkdiggler
Suspended
looks just like the hi-tech 911 cover.
Is Bender a site advertiser??
blade072
- Jan 12, 2008
- Jefferson, Ohio
- 2012 Vector LTX
dirkdiggler said:looks just like the hi-tech 911 cover.
I have a Hi-Tech 911 cover on my Attak and yes it does look the same.
I also have the adjustable nut that Duane sells. It allows you to adjust the primary sheave for belt wear. I have used this set up on my Blade, my 700 SX and now the Attak. Great set up. The larger bushing seems to eliminate any bind in the clutch.
Is Bender a site advertiser??[/quote]
Yep, they sure are.
Super Sled
- Feb 25, 2009
- Summit X
shaddow44 said:dirkdiggler said:looks just like the hi-tech 911 cover.
Yep, they sure are.
Ya, I've seen Bender adds on here lots of times.
But I don't think this post would be disallowed anyways because he's talking about a mod he bought and is using, not just playing decoy for Bender.
I like posts like this one, displaying new and innovative products that are out there that are helpful to the rest of the group.
Just my $.02!!!!!
Mike
Yamahammer485
Time for old post resurection....
The primary on both 4stroke Phazer and Apex are YXR's, however, the phazer has what appears to be a cast weight imbedded into the cover and the apex does not.
Does this mean installation of this cover on a phazer will casue a vibration issue?
I have a pic if no one knows that im talking about
Currently, bender racing is looking into this...
welterracer
Pretty
rotax454
Yamahammer485 said:Time for old post resurection....
Being an 07 Phazer FX owner, I would be interested in this Bender cover issue with the cast-in weight. Yamahammer 485, please do keep us posted on what Bender comes back with.
bottlerocket
149.00 pretty
Yamahammer485
Bender says that after looking at part numbers, etc.., the cover will work fine with no vibration issues.
Apparently the weight in the cover is just to counteract imbalance in the cover from the factory....
- 35K
- 13K
