Bender Stage2 turbo upgrade 2554 to 2860
sledracer
Kamloops BC
Has anyone done it? Whats involved with the swap? It looks like the exhaust is the same and both are a T25 inlet. Will charge tube mount up the same?
thanx Tyler
Justin at FPP has a 2860 upgrade for the Bender Turbo's. It's the same setup he uses for his Apex systems. Depending on the model 2860 used, he does some machining on the compressor housing so that outlet lines up with the tunnel charge tube inlet and to get the foam intake filter to fit as well.
Hmmmm I wonder if it wouldnt be better to modify the charge tube rather than mod the expensive turbo to fix the alignment.
