nswsparky
- Oct 2, 2011
- North Shore, MN
- www.nsw4x4.com
- Phazer
The battery I have in my 07 is less than two years old it is one of those expensive sealed battery. It seems to not put out the cranking amps when it is cold I just did the computer, springs light oil. It spins over so slow when it is cold no way for it to kick over. I even use it in my motorcycle in the summer so it does not sit for any amount of time. This thing should not be bad it cost $120. What battery is everybody using that works, puts out the best cold cranking amps.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Since its an 07, did you locktite the starter bolts?
nswsparky
- Oct 2, 2011
- North Shore, MN
- www.nsw4x4.com
- Phazer
I have not
- Nov 1, 2009
- 2009 Phazer RTX
take a look at this http://www.ty4stroke.com/viewtopic.php? ... highlight=
Load test the battery. I use a Deka battery. Stock size
nswsparky
- Oct 2, 2011
- North Shore, MN
- www.nsw4x4.com
- Phazer
is that that lithium ion battery? How well does that work in the monster cold.
Dalton
- Mar 13, 2013
- Chippewa Falls, WI
- Sidewinder XTX SE 141
Yamaha Phazer 2007 GT
Mine was doing the exact same thing. Had a brand new battery, a good one at that. When I first got it it turned over like a champ. Then for about a week it would turn over slowly in the cold especially and kinda slow in normal temps.
Then eventually it didn't start at all. Because of the starter bolts coming out. Ending up doing the loctite bolt fix and she starts right up!
This just happened to me about a week ago.
nswsparky
- Oct 2, 2011
- North Shore, MN
- www.nsw4x4.com
- Phazer
Dang I will have to dig into the bastard again just got the computer in, and the decomp springs, and the steering fix. I guess I have found a lot of loose bolts around the sled.
- Nov 1, 2009
- 2009 Phazer RTX
yes make sure you eliminate the battery before doing all that work.
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
I just picked up an YTX-14H- BS for my Phazer. Its 260 CCA vs 200 for the regular one. Paid $80. Its a Motorcross brand which is Yuasa's dealer brand.
3wheelerdude
- Jan 6, 2010
- Ottawa Ontario
- 2019 Voyageur 600
2019 ZR200
1991 Ovation 340
1986 XLV 540
Previous sleds: 1996 Vmax600, 2007 Phazer, 2016 Bearcat 3000
yamahas said:yes make sure you eliminate the battery before doing all that work.
Actually, it should be : Make sure you loctite the starter before anything. on 07's they all fail eventually, it will leave you stranded and it can be costly if not caught early.
- Nov 1, 2009
- 2009 Phazer RTX
Well it's much easier to get a battery load tested then to tear apart the sled. I agree it needs to be done anyway but if it's just the battery it may get him on the snow asap.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Anti gravity battery in the wifes Phazer. Expensive but holy crap does that thing crank!!
