Best scratchers for rx1??
mtmax700
Age
47
Klamath falls, OR
All yamahas- mt max 700, vmax 600, and RX1 mountain
Hey guys, my rx1 mountain has rail mounted spring scratchers on it already, but one is broken. I haven't ridden this sled yet but hey it's snowing right now! They have the clips on the bogie wheels to store them up.
I'm wondering if I should get another set like this, or does the rx1 prefer ski mounted? What is the best setup for these sleds?
Thanks.
scratchers are personal prefernce. i run rail mounted cable scratchers on the 2011 xtx as they can be run in reverse with deployed and gf doesn't know about having to pick them up. on the 09 , 16 and dads 05, we are using the running board mounted ones that have to be picked up when using reverse. both styles work well for me. youngest brother runs spring type rail mount scratchers on his 09 apex mtx and has good results too.
never ran the ski type yet on any sled.
Ok, I'm thinking about just staying with the spring type that are on there. Already set up for them might as well. I'll pull one off and see if it has any numbers on it. I have no reverse so I should be ok.
I tried the cable type scratchers twice and they broke on the first ride each time not to mention the damage to my slide rails. I installed the BRP scratchers that mount on the slide rails and they are awesome. You can back up without picking them up and they do the job that they're intended for.
