mtmax700
- Sep 20, 2024
- Klamath falls, OR
- All yamahas- mt max 700, vmax 600, and RX1 mountain
Hey guys, my rx1 mountain has rail mounted spring scratchers on it already, but one is broken. I haven't ridden this sled yet but hey it's snowing right now! They have the clips on the bogie wheels to store them up.
I'm wondering if I should get another set like this, or does the rx1 prefer ski mounted? What is the best setup for these sleds?
Thanks.
Thanks.
scratchers are personal prefernce. i run rail mounted cable scratchers on the 2011 xtx as they can be run in reverse with deployed and gf doesn't know about having to pick them up. on the 09 , 16 and dads 05, we are using the running board mounted ones that have to be picked up when using reverse. both styles work well for me. youngest brother runs spring type rail mount scratchers on his 09 apex mtx and has good results too.
never ran the ski type yet on any sled.
mtmax700
- Sep 20, 2024
- Klamath falls, OR
Ok, I'm thinking about just staying with the spring type that are on there. Already set up for them might as well. I'll pull one off and see if it has any numbers on it. I have no reverse so I should be ok.
Froggy
- Apr 29, 2016
- Kipawa,Quebec
- 2020 Winder LTX SE 17600 km and counting
2016 Viper LTX LE 23986 km sold
2015 Viper LTX DX Wife's 22500 km sold
2010 Vector LTX GT 25000 km sold
2024 SRX Leftover 3700 km
I tried the cable type scratchers twice and they broke on the first ride each time not to mention the damage to my slide rails. I installed the BRP scratchers that mount on the slide rails and they are awesome. You can back up without picking them up and they do the job that they're intended for.
DARKMAN
- Sep 27, 2023
- Harris, MN
- 2013 APEX SE
1981 ET340 "Frankenticer"
1982 SS540
1981 ET250 Mod Oval/Lemans Racer
Very happy with these on my 2013 Apex. Can reverse with them down, the tips are double sided for extended life, the replacement sets of tips are affordable too.
mtmax700
- Sep 20, 2024
- Klamath falls, OR
Those do look good. Hmm maybe I will try them.Very happy with these on my 2013 Apex. Can reverse with them down, the tips are double sided for extended life, the replacement sets of tips are affordable too.
mtmax700
- Sep 20, 2024
- Klamath falls, OR
Are these the ones with double springs?I tried the cable type scratchers twice and they broke on the first ride each time not to mention the damage to my slide rails. I installed the BRP scratchers that mount on the slide rails and they are awesome. You can back up without picking them up and they do the job that they're intended for.
RobX-1
- Coldwater, OH
X2. I too am curious to know more about these as well.
RobX-1
- Coldwater, OH
More specifically, am interested in knowing the part number for the scratchers since there are quite a few BRP scratchers and also where you chose to mount them.
Froggy
- Apr 29, 2016
- Kipawa,Quebec
I bought REV-XP Summit #860201728 and I ended up grinding a 1/4" piece of aluminum on each side to fill the window in the slide rail as shown in the highlighted circle and then I had to drill one hole in the rail for the spring mount and one through the custom fitted piece. Need to drill one hole for the bracket to support the scratcher in the up position.
REV-XP SUMMIT #860201728
