ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
NBSSR Ive been at this season being 1320 sure helps alot to hook....Normally i stud lightly for top speed runs but when the runs are shorter hooking up comes much more in to play. I think for this type of runs you want 4/bar MIN. I typically would go 3 per bar all up center using a 1.325 on 1" lug. If you radar more and trail less, you may even consider 1.450 on 1" lug. Also you may want to go up to 4 per/bar or even more. Many guys running there stud outer belts too. I still like a looser rear on trail so I stick to center.OK sounds like a rip2 is the track to go with. How many studs should I run? This will be a trail beast with the odd radar run as NBSSR runs here twice a winter.
Dan
