Jona$
Master
So have numerous problem withm my hero black 3
1.hangs at startup,charging sometimes.
2.records on display, shows both elapsed time and time left on memory but in real life the came can have already stoped recording, and as soon you press shutter button it hangs and you need to take out battery, this happens all the time.
3.Battery time is real low, can hold like 1hr 720/60 inside the house"have heard of a new battery comming"
4.should it really just rec 3hr22m in 720/60? my hero 2 with same settings makes like 4hr30m. this is with both the 32gb sandisk class 10 card, difference is there size.
5.When adding my bacpac to hero 3, the backlight goes on a rampage and blinks like a strobe, dont seem right.
6.alot of other small things happens, but wtf is this for crap? have problems with my hero 2 as well, when using it outside sledding with a bacpac, it only lasts like max 40min then the batteries are dead, if i just sat it out on the same temp and light setting it pulls of 2hr30min.
