SledFreak
- Feb 7, 2005
- Ontario. Canada
Does Yamaha sell Black handguards for the Nytro XTX?
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Yes I bought a set of Nytro black and put them on the 06 black APEX.
Hope that helps
Yamadoo
Hope that helps
Yamadoo
SledFreak
- Feb 7, 2005
- Ontario. Canada
Off a FX Nytro?
towerrigger
yamadoo
- Jun 3, 2003
I ordered them from the dealer. Not used off a Nytro
Yamadoo
Yamadoo
scott32
- Jan 12, 2009
- huron county, ontario
- 07 Apex RTX se, 09 Nytro XTX
Get the black/carbon fibre dumbo ears from Yamaha. These ears slide over your exsisting plastic protectors and provide better wind protection. At first you may think they look a little outta place, but after you get used to them they do look pretty cool. Matched up with med shield and side deflectors. The blue, red, and white were all sold out and on back order earlier in the season, black was all you could get.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Ok, Thanks Guys..
northerndoc
Might also want to consider a set of the Powermadd Star Series Handguards w/ RSI billet mounts. One good whack and those chincy yamaha aluminum brackets snap right off. RSI sells complete setups. If you want more wind protection, Rox makes extension kits that snap on and do a great job of cutting the wind down. I just couldn't deal with how the dumbo ears from Yamaha looked, plus after breaking one of the factory brackets by accidentaly bumping it- I knew I wasn't going that way again (boondocking in the woods can be hard on a sled).
jeffT
I have the rox hand guards (same as powermadd star series) be! I wasted $55 on the stockers, replacing them after one bad over the handlebars experience, and one deceleration on one running board and bumping (rediculous how weak those cast aluminum brackets are) they should build them out of a poly or plastic, it would probably be stronger than cast aluminum.northerndoc said:Might also want to consider a set of the Powermadd Star Series Handguards w/ RSI billet mounts. One good whack and those chincy yamaha aluminum brackets snap right off. RSI sells complete setups. If you want more wind protection, Rox makes extension kits that snap on and do a great job of cutting the wind down. I just couldn't deal with how the dumbo ears from Yamaha looked, plus after breaking one of the factory brackets by accidentaly bumping it- I knew I wasn't going that way again (boondocking in the woods can be hard on a sled).
Kråkan
I had a guy weld my brackets back together.. And he added app 3-4mm alu on both sides of the boltholes.. Now i have bent them a few times and they still just bend back.. PERFEKT!! Although a birch got my left plastics this weekend.. Damned tree to stand in the way!!!
