is it posseble to put a blow off on a supercharged nytro???
HYFLYR
yes
Not only is it possible, I believe it is recommended for any application over 8 psi or so.
I have a supercharger kit from Mouintain performance... were can I get a blow off four my sled????
Otis RX
At the links below. Jannetty Racing stocks them. Vortex
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
I do have a blow off on my MPI stage 3 rx1
dilley
space is kinda tight in the nytro. i used a bov from a mitsubishi 3000gt and mounted it to the intercooler right behind the headlight. any where else on the ic or a bigger bov makes it very difficult to get the ic in or out.
powderlites
Blowoff valve MPI Nytro
Here is what we did last summer.
11 psi boost Supercharger 220 HP and the guy is very happy with how sled runs from Fort MacMurray,AB
Head spacer, blowoff valve, RB3 Cam timming, PUMP GAS !!
http://www.powderlites.com
TBird
- Dec 25, 2004
- North of Sweden
- Sweden
- Yamaha Viper and Yamaha Nypex
Powderlites: What kind of BOV do you use?
Today i use a Vortech and is quite happy, but it is to small now when power got higher.
powderlites
MPI Blowoff valve
Same one we use on our turbo kits. we have mounts that can be welded in to any intercooler with 4"X 4" .080
Supercharger runs so hot without blowoff valve that steam kills all your power.
do you have any pics of a nytro with blow off so I can get an idea of were tu put it???
You guys think this should be done on MPI Stage one at 8-9psi? How will the Gem box work with it???
THANK You Skydog
THANK You Skydog
dilley
my dad and i both run mpi nytros @ 11 psi. one with bov and one w/o just as an experiment. we are running the same gems #'s and will have the same clutching as soon as i get the weights. With the bov is better gas mileage and substantialy less compressor surge.
dilley
What one are you running and where did you mount it?
dilley
i am running a mitsu bov from a 3000gt. it the same one that mcx uses in there kits. mine is welded to the top end tank on the front face of it. it is a tight fit behind the head light. only running 11 psi this bov is sufficeint. much more boost and it would not be big enough. the 3000gt puts out 14 psi.
