micaelaman
- Dec 3, 2014
- Sweden
- Sidewinder MTX 162, Arctic Cat M800 HCR
Hi,
I have an Nytro MTX 153" (2.5 challanger extreme) 2008 with MCX 270 kit. The sled goes like a rocket but eats belts for breakfast.
I bought it last year so i don't know if it setup properly.
I have a white spring in the secondary at 100 degrees and a blue-Brown-blue spring with non marked 82 grams weights on the primary. It also has a 3 mm shim between on the spring seat on the primary.
I have checked the alignment and engine position. I have also replaced worn roller bushings on the primary.
When i inspect the belt i can see that it starts to separate between the layers. This happens before it blows and i can feel it starts to slip more and more.
The record for a belt so far is 250 km.
Does any one has a tips what to do? Would an Green AC spring help? should i replace all bushings/rollers/rampshoes/springs?
givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
Are you using Yamaha belts ?
Ken...............
Ken...............
micaelaman
- Dec 3, 2014
- Sweden
yupp only standard 8DN belts.
My Yammi dealer loves me. He grinds his hands everytime i show up.
The sled has starting to sounds a bit strange en engaging the clutch. It squeeks like it slips. This started after a ride on a trail in low speed and steady throttle and no sudden WOT.
givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
100 degrees sounds awful tight on the secondary. That much squeeze will create a lot of heat. I don't have a nitro but I have run close to 300 horse on my rx1 and only run at 70 degrees and belts last a long time. Of course we're c0mparing apples to oranges here.
Ken....,.............
Same as Ken said, 1-6. Run 47 degree helix with purple EPI spring. Have this in my RX1 & Nytro, both mtn sleds turing 162 tracks. No belt issues with either of my sleds. Been on a turbo Yamaha since 2004, using oem belts.
Stigapex
Suspended
The white spring is to short. You will have a coil bind if you use it in 100 degrees. Its not possible for the secondary to shift full out with white spring in 100 degrees, that eat your belts. If I dont remember wrong I think max is 80 degrees with white spring
micaelaman
- Dec 3, 2014
- Sweden
Thanks for your answers
I have a shockwave helix lying in the garage,i will try it so i can get 47 degrees. I will also change the seconadary spring to a better one, like the green AC.
I will report after my next run
micaelaman
- Dec 3, 2014
- Sweden
