TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Just wondering what clutching everybody running? I have blue silver blue primary spring with 66gram weights (dalton pro)......not to sure on the profile.
The secondary I have stock helix with blk white stripe spring set on 70%.
I still hit the rev limiter one in a while.
obr
- Aug 16, 2005
- Alta, Norway
- www.techservices.no
Primary yellow hauck, 78 grams daltons,
Secondary Shockwave, with stock spring. easy to adjust. works great.
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
TURBLUE said:Just wondering what clutching everybody running? I have blue silver blue primary spring with 66gram weights (dalton pro)......not to sure on the profile.
You definately need more weight in the front clutch.
Get a set of Supertips and I will help you dial them in put the secondary back to 3-3 when you get the weights.
At 260 HP you need to start at about 78 grams depending on front spring.
I was running 84 grams at 274 hp with a Dalton green.
travelor
I am running the same set up as turblue, Dalton weights are suppose to be equal to heavier weights. Mine is great at 9000' at 11 lbs. and with the 47/51 would work good at 17 lbs. 10,500 to `11000 rpm.
