blowing headlight fuse on Rx-1 any suggestions
What have you checked so far? Start with the handle bar pad and with a multimeter check the blue wire with the white stripe coming from teh dimmer switch, see what the resistance is.
jonnyturbo said:
blowing headlight fuse on a rx-1 any suggestions
do you have a heated shield.......if so it might be grounding out by touching something metal.....it happened to me and blew the fuse
