blowing oil out of breather
Buckeye said:
MONSTERTURBO said:
where do i get on of these from? leaving for canada tomorow and extended the breather with 3/4 line 18" up toward the steering column for now, hope this gets me tru the weekend..
Add a second vent to help alleviate the problem. You'll need to anyway to put the LP kit on. Put a 5/8" Tee into the line returning to the metal Tee on the top of the Oil Sump. Between the Metal tee and the engine, The line comes from the front of the crankcase. Run the new vent line up to the steering column and put a pvc filter on it as a temp until you can get the LP box. The LP box comes with a fitting that screws into the valve cover and serves as both a third vent and a box drain. Not that it drains, because the oil never gets that far.
Just be careful if you ride mountains an tip over. Could leak oil out of that tee.
Otis Rx: I have about 6 gallons of 110 Sunoco with 4 gallons of 93 Sunoco because my transducer was wacky on my Bully Dog guage.
On low boost it was spiking to 11 lbs and settling in at 6-9 lbs. So one time I put the switch on high boost just to make sure the switch was not bleeding off pressure and going to high boost. I went about 100 ft, the guage spiked at 23 lbs and settled in at 15-16 lbs. Mike at Benders sent for a new transducer for me. When mine went bad they were testing a stage III and there guage would only read 6-7 lbs.
I had changed actuators and everything and was running soo much 110 because I did not want a melt down if the sled was really making 11 lbs of boost.
Sled has less than 100 miles, would like to get at least 500 before playing w/high boost. No snow :o|
