Bog
MikeWalters
Saskatchewan
Canada
2007 Phazer
Anyone else notice a lower rpm bog when they added their exhaust?
I had a slight bog with the Aaen pipe, and now that I added the Mod air box it is quite bad.
My PCIII did not fix it, but I am still investigating wether my PCIII is working or not...
Anyone had this?
I had the same thing. installed the PCIII from Ulmer and it cleared it all right up.
you should see the PCIII lights come on...
cannondale27 said:
Check your belt height also.If to low could cause a bog.
I think when I checked it was about level with the edges of the secondary, where should it be?
If you have reverse thats about right.If not get it so the ribs of the belt are over the top of the sheave edge.
I'm having the same problem.. Got pc3 , ram air cover, ulmer's clutch kit and map. . Any of you guys tweaked anything to cure this problem?
