NY_Nytro
- Dec 24, 2004
- Grand Island, NY
- www.gi-snowmobiler.com
I'm here at work and just wondering anyone knows the length of the bolts used on the stock Apex riser? I can pull one and measure when I get home but was hoping someone may know so I could stop on my way home and get slightly longer ones. Thanks!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Hey bud....
Just be sure what year....the bolts and risers are different from 06 to 07 and up.....
Dan
Dan
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
Dan,
Thanks for pointing that out. I looking for the bolt length on a 07 Apex
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Ok....i think i can help then...since i had changed my 06 setup to 07 bars and riser,but then removed it all went back to 06 setup..lol....
so I think i have it all sitting in the shop loose and I can measure them....
do you know the thread size?..you just want length?
ill check now...brb
Dan
ill check now...brb
Dan
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
Thread size will help as well. Thanks Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Ok...got it....
07 riser bolts- 7-1/4"
06 Riser bolts---6-1/8"
Both measured by actual shaft length without head included
Ok the threads look to be 7mm.....be very careful here,as you must get proper threads so the new bolts will thread into the sled....
you might be best to take a stock bolt with you to be sure the threads are right....should be 7mm from my measurment though
dan
dan
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
Thanks Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
no problem.....had the stuff right here.
Dan
Dan
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
Can't find any longer than 6", even checked online at Nut & Bolt only sites.
Not a big deal I just had a 1" Powermadd riser block lying around and with 1" longer bolts I could have installed it at the base.
Maybe the Mountain Apex riser bolts would work? Anyone know their length?
LJ 452
I thought that the 07' riser was shorter than the 06'. If the 06' is longer and you want one let me know as I have both the stock 06' and the Mtn. 06' riser and bolts available.
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
Honk
I could not find longer bolts either, guess I;ll go with the Rox riser that gos on the top
