hereismylife
I see the Apex bearings are molded in. What options do I have to replace them?
Thanks Joe
Thanks Joe
gitrdun
If the wheel is still in good shape, on the 5", you should be able to remove the seal and put new grease in there. If the wheel is trashed, I believe the replacements from yamaha all have replaceable bearings.
or any of the aftermarket wheels that fit those locations.
hereismylife
No the bearing were never greased and seals are no good. I see the bearings are molded in the idler boogies. Need all 6 boogies and looking for a cheap replacement.
Yamaha offers the updated spoke style wheels ( 5' and 7") that have replaceable bearings. Kimpex also has a for replacement wheel.
Pictured here are the Yamaha wheels.
hereismylife
Where do you find them at? How do you look them up?Yamaha offers the updated spoke style wheels ( 5' and 7") that have replaceable bearings. Kimpex also has a for replacement wheel.
Got all mine from the local Yamaha dealer
hereismylife
Ok ty
Kimpex part number is 04-116-96s
Good quality wheel, but not spoked.
hereismylife
Thank you
vipermike2002
- Jan 19, 2006
- Barrington, IL / Rhinelander, WI
- 07 Attak
I have been replacing mine with these... (Best deal Ive found)
https://www.ebay.com/itm/Yamaha-Idl...:CG0AAOSw7F9dON1G:sc:USPSPriority!60013!US!-1
That is a pretty good deal.I have been replacing mine with these... (Best deal Ive found)
vipermike2002
- Jan 19, 2006
- 07 Attak
Not sure if you get a better deal buying directly from Port Yamaha verses The PY eBay store but I called a few local dealers for me and they all wanted like $35 each for them.
hereismylife
So they are the same ones for a 09 apex gt?
Excell Motorsports also has replacement wheels. They are slightly larger than factory to help with slider wear
https://excellmotorsports.stores.dealerspike.com/product.aspx?zpid=6635889
Listed to fit 06-16 Apex
