Joseph Levandoski
- Oct 19, 2016
- Ellington, CT
- 2019 Yamaha Sidewinder X-TX LE 141
I've been looking to add a boost gauge to my SideWinder (just as one of those things to add - I wish Yamaha gave us one right from the factory). Since there doesn't appear to be an accessory vacuum port off the intake plumbing, I was looking at the Precision EFI silicone charge tubes, but I'm not sure about a gauge and mounts (stock boost is about 13 to 15 PSI, correct)? If possible, I'd like to install the gauge above the speedometer or tachometer instead of anywhere else to keep it looking clean. Since I'm running a stock powertrain, I don't care to install an AFR gauge.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Stock boost is about 9-10.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Just get a tune, then you will have boost on the factory gauge. Plus you will have the added bonus of more power and better fuel mileage.
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
x2
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Travis at BOP making a GPS mount like the old OSP mounts that sit above the speedo/tach. Could be drilled to hold boost and/or other gauges. Just a thought.
Joseph Levandoski
- Oct 19, 2016
- Ellington, CT
I would love to get a tune, trust me - but so far, my chain case hasn't been able to handle the stock power.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
So fix the chaincase. All you need to do is weld the roller screws and make sure you have the tensioner back off 1.5 turns. I and many others run around on the big tune all the time. Chaincase is fine once you weld the screws on the roller.
Joseph Levandoski
- Oct 19, 2016
- Ellington, CT
I'm not sure that was the problem - I was hitting quite a few jumps and heard a bang followed by grinding. Pulled over to the side and found my secondary spinning while the sled was stationary (the nut holding the tensioner screw was still tight in the chain case). Sled was rideable, but we'll find out more when the dealership finishes the teardown and warranty work.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Yea it was all that power that broke something.....nothing to do with jumping.
Joseph Levandoski
- Oct 19, 2016
- Ellington, CT
Technically the track never left the ground. If Yamaha advertises the SideWinder to pull small wheelies, I should be able to do the same.
KnappAttack
- Feb 19, 2004
- Welch MN
The chaincase can handle all the power you can pour thru the 998, trust me. You aren't going to tax it on any of the available tunes unless the rollers screws back out, or the top gear bushing goes bad. These are maintenance items that need checked every season when changing chaincase oil too.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
100% do the require fixes and ride the carp out of it..lol !!So fix the chaincase. All you need to do is weld the roller screws and make sure you have the tensioner back off 1.5 turns. I and many others run around on the big tune all the time. Chaincase is fine once you weld the screws on the roller.
0 issues here!!man I launched my sled multiple times today on small hills on trails and landing with the throttle to the bar on my 300 header tune and sled almost ripped.my arms out of sockets..lol
Over 300 km today of hard riding!! Tomorrow she goes on lift and get a good inspection and back out Thursday riding the crap out of it
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Yea and Bill Clinton never inhaled.
My tracks only on the ground about half the time on bumpy trails. Not sure how you could be hitting jumps without the track leaving the ground? Sounds like backpedaling 2 me
