phazerboost
Thanks ak
ak
phazerboost
Quick question. Do you know if those prices are before or after the 30% online order discount?
ak
Im pretty shure the discount is already in that price? there the cheapest ive found the competion wanted 105 to 120 dollars for a factory skid plate and they only charged 75 dollars, they were quick to ship also I dont know how well are fast it will cross the border.
phazerboost
Anyone planning on losing the revererse will need a few plugs and a seal. Yamaha part numbers are
90338-10011-00, 93102-26398-00 and
90338-07008-00. You will need 1 each of the first two numbers and 2 af the last number.
ak
What plugs and seals are different? Are where do they go?
phazerboost
Two plug the holes that are used to bolt the reverse box the the chassis on the inside of the chain case cover. One is used to plug the oil supply to the reverse box which would serve to oil the top of the heat exchanger with the reverse out. And one oil seal which seals the jack shaft and the inside of the bearing housing to replace the o-ring in the reverse box which sealed on the outside of the bearing housing.
ak
found the plugs where is are what number is 93102-26398-00? Cant find this on the same page as the others.
phazerboost
Frame
phazerboost
It took me about an hour to figure that one out.
ak
Right on thanks I will be ordering my parts in a week are so If there's something else let us know. Thanks.
phazerboost
You will also need a bearing on the clutch end of the jackshaft. Yamaha part number is
93399-99959-00.
93399-99959-00.
ak
Did you do your reverse delete yet? I got all my parts just seeing if it worked and wiring works correctly.
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
- 14 Viper LTX, 10 Turbo Phazer MTX, 08 Phazer, 88 SnoScoot
93399-99959-00.
I know this thread is ancient, but its the only thread/information I have found after hours and hours of searching. Did either if you ever accomplish the reverse delete?
