Boot burnt on 05 rs venture
big_ry_ry
Buffalo, NY
I was riding today, not the best conditions and I felt my left foot warming up, did not think anyhting of it and i looked at my boot and the left boot on the left side is blackened and smells like gas and or exhaust, I can see little indents on my boot from the metal pattern?
Anything i should look for, it is dark now so i want to look in day light but i can not think of anything but the belt is maybe going?
I dont know just a little confused..
boot
Here is the picture of the boot
electric sock malfunction???
that being your left boot puts it to the outside???hmmm there ain't nothin" out there except the boot hoop, right??/
a coolant hose runs along the tunnel to feed the running heat exchanger on our rage.
are you sure that isn't just the aluminum leaving a rub mark from general riding preasure?
I know the top of my boots get that way from hooking the foot holds.
And even on a 4 stroke you will smell gas and exhaust to a certain degree.
just my .02.
The fueltank over flow runns down that side could cause gas smell on your boot.That side is always hotter I am surprised that you have not noticed it sooner. That does look like aluminum on your boot.
I would check the drive shaft bearing just to be safe.
boots
They are the same boots I have allways wear.
My right boot does not smell like gas, and the only boots i wear, they were in the boot hole.
I chanced it and took a ride last night at my cabin a lot better conditions, I think maybe my sled was running hot because it did not do it last night... Weird.
I just had the service bulletins done on the sled and this was the first ride since all the work has been done.
I did not have a chance yet to look at it i had to come home for a little and i am going back to my cabin for more riding I will look at it then and keep a close eye on it.
It is not alum. on it it is actually burnt, the rubber is a little deformed and on the side a little higher you can see impressions on the rubber.
