hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
With a few reported leaky gaskets lately yesterday I decided to test a gasket from current stock just to see if there was any noticeable issues. I did not change suppliers but that doesn't mean material integrity may not have changed. Had no issues during my testing and put 50psi of pressure to it. Beings I spec it at 6 ft lbs, I'm wandering if it is too low on a 150 ft lbs wrench. On a 150lb wrench it may not yield as precise of a torque at such a low rating. I always use my inch lb wrench as its more precise on a lower rating. Maybe I need to encourage the 72 inch lb spec with an inch lb wrench??
Here is the video from my test yesterday.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Used inch pound wrench @ 72.. 2000 miles. No issues
justinator
Used inch lb wrench as well and I believe I went 78inch lbs( 6.5ft lbs). 3300ish miles last winter plus whatever new owner has done since purchase. Didnt have any issues.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
What I've seen so far in terms of failures I would attribute to a Homemade ROV delete where the tip is solid with ice.
But we have to Blame Somebody. Sorry travis....
I watched your video the other day And was going to post it up to facebook But I didn't feel like that was my place.
DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
I also used 72 inch pounds and have 5,000 miles or more on it so far with no issues whatsoever.
earthling
Several people on FB reported leaks but at least two of them were over torquing having read the service manual wrong.
sideshowBob
I have had Travis's BOP oil tank gasket installed for two seasons now...works perfect.
- 47K
