Bottle size
cire said:
Is it something that can be built or am I better off purchasing one? Thanks Stoutner PS the zip ties I see must be the bottle heater...
I mis-spoke. The 2 bolts for the voltage regulator only need to be taken out if you need to relocate the regulator. If you do, take out the bolts, move the regulator around to the back side of the bulkhead that it is botled to and use zip ties to secure it.
As far as the bottle brackets. Here are several pictures. Yes you could make the easily enough if you had a set in your hands to copy. Maybe it'd be easier to just buy from boondocker. These brackets get bolted the studs that bolt your delta frame to the bulkhead. If you take your hood off, you will see the four nuts where the bulkhead and delta frame are bolted together. remove the inner two nuts and bolt these brackets over the delta studs. Reuse the existing nuts that came off the studs.
