Nitrous on Phazer?
obr
Alta, Norway
Website
www.techservices.no
Anybody running any nitrous kits on a Phazer yet?
In that case, where did you mount the bottle?
What kit are you running?
Was thinking about mounting a Boss kit on my Phazer, but I'm not convinced yet....
Thanks. :4STroke: :nos
yes, I have it, but haven't run it yet. No snow. Holtzman kit, the bottle is mounted in the front.
Ok, thanks, Why did you go with the Holtzman?
I can get a used ICE for a fairly cheap price, but I can also get a Holzman out of my friends REV for a good price. I'm just not sure witch way to go.
I've haven't played much with nitrous, but I like that you can bring it back to stock when you sell the sled, a turbo is to much work putting back to stock.
And, on these kits, there are nothing like a boondockers, or tfi box. Shouldn't you have that, as the sled is EFI?
I went with holtzman because of the simplicity of the kit. The toughest part is mounting the bottle. The one in the pic is a 1.7lb with a different valve for clearance. I think it has the cleanest install of the others I've seen. There isn't any kind of elec. box added, this is the same setup as what's used on the apex sleds.
Ok, thanks. How does this kit add fuel when on the bottle?
I think simplicity is important, but I know they've had trouble making those kits work on some Rev's. Hope you get snow soon... :nos
Fuel is added into the air-horns in the airbox. Same as the apexs/RXs.
Yup, that is just awesome!! Same simplicity as the Apex kits!! That's why I went with the HOLTZMAN kit also.
December Snow Tech Mag had an article on adding nitrous to phazer.... just thought i would pass it on.....
Any updates on how the sled worked with the N2O? Thinking of a FX sometime but wondering if the nitrous would get the sled to 100mph on a lake. Thanks!
