Brake cleaner streaks on windshield
PAvector
Pennsylvania
2014 Yamaha SR Viper
Have a windshield that has streaks from brake cleaner sprayed on it. Anybody have luck saving a windshield like this or is it trash? Tried Honda polish and alcohol, no change.
try some rubbing compound. You may need an aggressive grit. Then polish it out.
May or may not work. I have done some older windshields on a sled I had with good results, but it was just haze, not brake clean streaks.
make sure that alcohol is 90%, if not then use mineral spirits. A good mild rubbing compound for glass is toothpaste and water, don't laugh, just don't let it run because it cakes-up when it dries makes a mess. Good luck
You could try a headlight restore kit. Most come with everything you need to polish plastics.
