daveh
- Apr 29, 2005
Don't know why this did not post earlier but did anyone add the brake lever to their sled? Picking up my new Apex ER Sat. (first Yami) and was thinking I would have the brake lever added before I get there.
Or, maybe it is so easy to install,, a mechanical reject could do it (that would be me). Is it worth getting one?
Thoughts
Dave
Thoughts
Dave
Convert
Are you referring to the parking brake? Unlike Polaris Yamaha's come with it installed if thats what you mean. I had a 98 Pol that never had one!
Tork
daveh said:Don't know why this did not post earlier but did anyone add the brake lever to their sled? Picking up my new Apex ER Sat. (first Yami) and was thinking I would have the brake lever added before I get there.
Thoughts
Dave
Hooked brake lever?? Would be real easy unless there is loctite on the bolt
LazyBastard
I doubt that loctite would stand up to a wrench like THAT...
leaddog
I have the hooked lever on order, but now that I have my GT, I kind of like the stocker. If I had it to do over again, I would probably save my money.
ccso85frigu
I put the lever on my attak tonight, it is easy...I have done it to my last three sleds
leaddog
Do you like it a lot better that stock?
ccso85frigu
yeah, I am an aggressive driver and it helps a lot
leaddog
Thanks. I will continue to wait for my order. 8)
daveh
- Apr 29, 2005
Hmm,
Maybe I will wait for the first ride or two then add it and compare.
Just a one bolt change over. Sounds like something I can do.
Dave
Dave
POWERHAULIC
As good as the brakes work on these sleds, I like using just one finger on the stock setup.
Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
I don't think it is a matter of how good the brakes are - it is when you ride a sled with hooked bars like the Apex's have you tend to hold on out on the hook with your left hand and when you go to reach for the brakes from there you can't reach the lever. I know when I demo rode the Apex sleds last spring that was one thing I walked away thinking was that the sleds needed a longer brake lever.
sledheadgeorge
ccso85frigu said:I put the lever on my attak tonight, it is easy...I have done it to my last three sleds
got any pics of it?
- 10K
