Tcat100
- Jan 16, 2019
- Chicago
- ZR9000
one thing to keep in mind is that if you run a steep (fast upshifting) helix, it will cause your brakes to wear out noticeably faster if you do a lot of trail riding. Another reason to strike your clutching balance with an appropriately shallow enough helix (especially the start angle) if you trail ride lots of miles. In my experience steep helixes can cause rotors to overheat and pads to wear crazy fast because there just isn't enough backshift. Just a thought...
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Disagree. I ran a straight 45 for 12K miles.. The TP orange spring cranked to 6/3 and ZERO issues with backshift. I never used my brakes hardly.. I'm on a straight 38 now and its SLIGHTLY more back shift.. Very little difference. HH weights loaded all on the heels and tips.. I feel this is a factor also,.one thing to keep in mind is that if you run a steep (fast upshifting) helix, it will cause your brakes to wear out noticeably faster if you do a lot of trail riding. Another reason to strike your clutching balance with an appropriately shallow enough helix (especially the start angle) if you trail ride lots of miles. In my experience steep helixes can cause rotors to overheat and pads to wear crazy fast because there just isn't enough backshift. Just a thought...
Tcat100
- Jan 16, 2019
- Chicago
- ZR9000
I disagreeDisagree. I ran a straight 45 for 12K miles.. The TP orange spring cranked to 6/3 and ZERO issues with backshift. I never used my brakes hardly.. I'm on a straight 38 now and its SLIGHTLY more back shift.. Very little difference. HH weights loaded all on the heels and tips.. I feel this is a factor also,.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
All good..I disagree![]()
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
You run any big helixes?I disagree![]()
Tcat100
- Jan 16, 2019
- Chicago
- ZR9000
I got a collection of helix's that should go to the Smithsonian when I die
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
What you got for the 3 roller Yamaha secondary ?? I might take one off your hands. I only have a few.I got a collection of helix's that should go to the Smithsonian when I die
Tcat100
- Jan 16, 2019
- Chicago
- ZR9000
sorry i run the stm tuner secondary so old school cat styleWhat you got for the 3 roller Yamaha secondary ?? I might take one off your hands. I only have a few.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Bringing this around to the top. I must be riding faster and faster as I get older. I need better brakes. Last few weeks I've tried a lot of things to improve my brakes to no avail.
I wire brushed my stock pads again, no workie, those things are completely toast and just wont stop like when new, and my gawd are they pricy to replace. I removed the pistons, cleaned and refilled with fresh brake fluid.
I tried the new Niche semi-metallic pads I bought off e-Bay. I think they must be half gone by now as I see the fluid level getting lower. The smell off them is extreme, a cross between a grinding wheel and of course clutch or brakes from a semi. Ohh they stink when you grab a handful on them. They don't bite hard enough and they are not going to last any time at all, I can feel them grinding away with ever hard stop.
Has anyone tried the full metallic ones off e-Bay from SPI? Wondering how they would do. It seems I can cook any of these pads. Wondering what works for the guys who have tried aftermarket pads. I'm still using the stock race disc the LE came with and its in fine shape, just would like a set of good pads that are one-finger, even two-finger braking. I need something good I can drive in deep with a lot of power on a heavy studded track and know I can get things hauled down reliably. Seems like pad choices are limited.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
I’ve found the full stock rotor to be the best for breaking and wear
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
It really sounds like stock pads are way to go, and by time you have invested in all the cheaper ones or replacing them more often they will be cheaper a less hassle than any these others. Ebc may work well and be cheaper but again less longevity. I’ve noticed even in vehicles that factory rotors an pads are the only good solution for daily use.Bringing this around to the top. I must be riding faster and faster as I get older. I need better brakes. Last few weeks I've tried a lot of things to improve my brakes to no avail.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Pads like tire compounds trade performance for wear. Not saying cheap-cheap pads are either but high performance pads simply do not last long. You can have long wear or you can have grip ...
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Why would you wait to 4500 miles to change belt or broke, didn’t the belt become thinner after 2000 and lose performance,just curious.I’m in same boat. Ironically It became noticeable after I blew my first belt at 4500 miles end of last season. I scuffed rotor with brake clean and scotch brite when I swapped track this fall with 0 change. Bdx rotor and some new pads are my next stop
KnappAttack
- Feb 19, 2004
- Welch MN
OK, stock pads it is. I'll order them today. Seems like the aftermarket pads are lesser than.
stgdz
- Mar 27, 2021
- Buffalo MN
Hayes sells a floating rotor
