Okay I took sled out of trailer last week. I believe I used the brakes then and they worked fine. Doing some clutch work so engaged parking brake to get belt off. For some reason I tried brake today and nothing. Just a click noise at Caliper. Hand bled the heck out of them, MityVac for Vacuum bleed. Nothing. Think Master is shot?
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
Not Good , you put new Caliper last year so you would not think that is gone all ready.
Right and not getting any air out just fluid. Buggers don’t sell a kit either. Have to get whole master.Not Good , you put new Caliper last year so you would not think that is gone all ready.
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
Maybe the Caliper is warranty for a year?
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
I’d say the master went. Any pressure build at all with a quick squeeze? I’m not a fan of parking brakes that require you to use way more pressure than one would normally use to set the park lever. Your basically putting maximum pressure on the brake system for the entire time the park brake lever is on.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
YupOkay I took sled out of trailer last week. I believe I used the brakes then and they worked fine. Doing some clutch work so engaged parking brake to get belt off. For some reason I tried brake today and nothing. Just a click noise at Caliper. Hand bled the heck out of them, MityVac for Vacuum bleed. Nothing. Think Master is shot?
No pressure at all. Took master apart and cup looks fine but it can just fall into the bore. Cleaned everything up and put back together. No change. Nothing. It’s almost $150 for master. Maybe warranty.I’d say the master went. Any pressure build at all with a quick squeeze? I’m not a fan of parking brakes that require you to use way more pressure than one would normally use to set the park lever. Your basically putting maximum pressure on the brake system for the entire time the park brake lever is on.
Buddy and I tried again 3 hrs later same results. Anyone have a source for a Rebuild kit for Hayes? Tell ya what if in fact I have to pay $150 for master first thing I am doing is cutting that Parking brake off
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Barn of parts got any masters? Maybe take it apart and find out what the bore size is and maybe match on from a motorcycle??????
Did you leave the parking brake on over the summer?
Yes it was left on for couple days after removing belt. Work once after and never since. Took Master apart. Should have took pics. Cheap piece! Only one cup in it and a O-ring. Very simple. Trying warranty monday. Expires 12/01/18.Barn of parts got any masters? Maybe take it apart and find out what the bore size is and maybe match on from a motorcycle??????
viper strike
- Dec 22, 2016
- belle plaine mn
- 2015 yamaha sr viper ltx dx
Never leave the parking brake on long term in any machine. A day is to long in my book even 6 hours. Its meant for parking on hills, not in your trailer.
This is what makes them go bad.
Yes everyone likes the added security when hauling them around, but it will make them go out.
Believe me I wont anymore. Picked up new Master and it gravity bled in about 5 minutes! Good to go.
mtcooler
- Dec 16, 2013
- Newton Wi
- 2014 ZR 7000 LTD Sno Pro
Did warranty cover it?
Assuming so. Didnt pay for it. But not sure whether it was submitted yet. Had one in stock.Did warranty cover it?
Found that Coolant leak too. Have to remove or move Jackshaft support to get at the clamp properly. Thanks for trying to help mtcooler!
