usaf167aw
Is the brake switch on my XTX adjustable at all? the reason i ask is because the brake light only comes on intermittently. If i mess with the brake lever it come on and sometime blinks, so it almost has to be the brake switch itself. or has anyone ran into an issue like this?
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Sounds like a short in the wireing more than anything. Check your connections
Radar22
I had this happen before replaced brake light switch under the brake Handle that turns the brake light on and off
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
remove the switch, take it apart, clean the contacts then put a little anti corrosion grease on it. Mine did the same thing a couple of years ago and it was a simple fix.
usaf167aw
Just the info i was looking for. thanks a bunch
grizztracks said:remove the switch, take it apart, clean the contacts then put a little anti corrosion grease on it. Mine did the same thing a couple of years ago and it was a simple fix.
