Broken Exhaust
Yes but then I welded them and closed the tunnel and never had a problem after.I believe the giant Ice chunks from open tunnel beat the heck out of exhaust + weak weld area cause crack right at manifold.
yup mine broke and if you look at the stock weld it looks like the pipe is pressed in then tac welded, the guy who welded mine went all the way around on the out side looks like a much better weld, they broke at 1550 miles now has 2000 on it and it seems ok
