Broken Monoshock Adjuster Cable
FLYBOY
Ottawa ON CAN
Found my 2006 Attak shock adjuster cable (tunnel to shock) damaged.
The rubber coating has separated at each end and squared key shape on the shock end pulls out of the threaded connection on the shock. Any body else have to replace this. I imagine so---7200kms on my sled.
Yup, a few times, ussually because I'd lower the rear of the skid to much a pull it out from the connection. :o| Not too bad price wise, I think $8.00 or somewhere around there.
My 06 Vector broke 3. I won't even bother replacing. I set it where it rides decent and left it. I RTV'ed the broken end of the cable and screwed it back into the shock. If I want to adjust, I still can, I just have to use pliers to unscrew and then use a small screwdriver.
