Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
Some of each there is 52 rivets it i would say 35 have holes already drilled get a air or peundrauilc riveter the structural ones are tough.
marathon mike
I assume they're not colour coded rivets either just natural
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I have my skidoo linq can mounted on whiteout technology brackets on my xtx 137 and just ran 300 hard miles with no issue.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
The structural rivets are natural and the rest are black
75northface
- Oct 26, 2016
- Sudbury, Ontario
- - 2017 Sidewinder XTX SE
- 2016 SR Viper LTX DX
- 1997 Mach Z
That's good to hear! I just mounted mine (Linq can) and was a little skeptical...
dgjr636
- Nov 16, 2013
- Clarence NY
- Sidewinder LTX LE
I put over 3000 miles on a 137 Viper with 3gal LinQ fuel caddy and a medium LinQ bag filled. Rode it like I stole it and never had a problem. 137 Winder tunnel is also 2&1/2 inches shorter the 137 Viper tunnel. Should not be a problem.
It is a good idea to spray the underneath side of tunnel with silicone or Wd-40 to keep any access of snow or ice build up. Early Cat Pro-cross chassis sleds would bend tunnels but after spraying them we never had a issue after.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
Have 900miles on my winder BTX with the bumper installed no more issues hopefully short tracks don't have issues but BTX and mtx guys should get bumpers saw one bent up today wheelied and bent it up 2 in!
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Yeah go read the MTX forum. Guy basically broke the back of the tunnel off!
Josh Cooper
- Dec 23, 2016
- Maine
- 2015 Yamaha Viper Mtx 153 se
View attachment 124032 I have a 2 gal gas can and a shovel pack on my BTX LE and the tunnel is now bent by the rear of the running boards the sled had 80 miles on it with 50 of them with the gas can mounted. Trails were not very rough I'm not sure if the shorter sleds will have the same problem!
So I just took my mtx on the first ride of the year and the day after I noticed I bent my tunnel just like you had. Did you have to replace the brackets where it's bent before you put the new bumper kit on?
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
My suspension brackets weren't bent it was all in the tunnel I hung it by the bumper and jumped on running boards till it was straight then c-clamped he sides back straight the best I could and then when I installed the bumper I had to c clamp it to the tunnel to get it to fit tight it looks like brand new now
customnytromtx69
tnc110
- Jan 5, 2015
- Sidewinder BTX SE, SRXs
What is part number for 153 sled. White.
SUC_doo
- Jan 4, 2017
- Collingwood, Nova Scotia
- 17 sidewinder rtx, 08 apex ltx gt, 01 formula deluxe
