mulderdad
I recently had my front left bulkhead bottom a-arm holes welded/filled ( one was oblonged bad and the other was completely broke off) and now ready to re-drill the holes.
First question is what is the distance from top hole to bottom hole center to center? Can anyone verify a width of 18mm on the bottom a-arm holes?
Thanks,
Rick
Thanks,
Rick
mulderdad
PLEASE??
mulderdad
Nobody has there apex ripped apart right now???
AIRWOLF
Guest
- Oct 1, 2004
- New York
- www.sledpartsgarage.com
let me look I have a 2008 Apex bulkhead in the garage
mulderdad
Can you measure center to center on the bottom holes of each side of the front bulkheads together?
Thanks,
Rick.
Thanks,
Rick.
AIRWOLF
Guest
- Oct 1, 2004
- New York
mulderdad said:I recently had my front left bulkhead bottom a-arm holes welded/filled ( one was oblonged bad and the other was completely broke off) and now ready to re-drill the holes.
Thanks,
Rick
I only have the Right side
18mm hole dia
top hole to bottom hole center to center 82 mm
mulderdad
Thank you very much mr. wolf.
Cheers,
Rick.
Cheers,
Rick.
