mulderdad
So I started to put my wounded apex back together yesterday anad have run into a snag. I re-installed the front bulkheads and ready to re-rivet. Problem is I have two brass coloured bushings that measure 40mm in length, 14mm diameter and 9mm inside diameter. At first I thought it was ski bushings,but they are not for the skis. Then I thought they were for the engine mounts, but the bolts are too big that go throught the mounts for these bushings. I don't know, i'm stumped.
I spent 5 hrs yesterday trying to figure where they go.
Any ideas??
Thanks,
Rick.
Any ideas??
Thanks,
Rick.
turbine man
bushings
mulder they might be the 2 front steering bushings that go thru the flat arm under and in front of the battery location??????
mulderdad
I checked and those bushings are in already.
Anyone else have a guess???
SLEDSTART
Did you look at the film???
mulderdad
Finally found where they go!
They go in the plastic steering peice, the one with the tabs you bend over that locks the nuts in place. I decided to take the bulkhead out again to see what I missed. Took all the steering apart and voila. Don't know how I missed it. Thank you very much guys. I can now finally start riveting.
Man there is a lot of rivets to put back in!
Cheers,
Rick.
Cheers,
Rick.
SLEDSTART
Glad you found it. Have fun. I took one apart. Would not want to p0ut it back together!!!
