Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Center shaft of primary is a bearing ,belt super tight, no drag, just spins.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Quite messing with the guy NitroThey have a needle bearing in the primary where the shaft normally creates drag on the belt.
Fast
- Sep 25, 2018
Ok are we looking 1" exactly or is there a tolerance,i cant seem to find that in the manualThey haven’t had the auto tensioner for many years. I don’t believe the 9000 has ever had it.
No forward or reverse trouble?
Uhm well the reverse actuator has been failing on cats for years.
Anyone who sets deflection by how far the belt rides up in the secondary is doing it wrong. Deflection is exactly that. How much the belt DEFLECTS when when pushed on, is the proper way. Differences in center to center and belt lengths can cause a belt to ride at a different height in the secondary.
Turboflash
- Mar 18, 2019
- Southern MN
Because of that needle bearing in the Team primary, the belt on Cats can be (and is) very tight without affecting ability to shift. In fact, even with belt tight and engine running, you can pull the sled backward pretty easy. It seems to work.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
It’s new for 2018 tho, they didn’t have it for years. It should help with the reverse actuator longevity.Because of that needle bearing in the Team primary, the belt on Cats can be (and is) very tight without affecting ability to shift. In fact, even with belt tight and engine running, you can pull the sled backward pretty easy. It seems to work.
If you want your reverse to last longer set it looser. Over an inch. The engagement will be harsh tho. Jumps a bit when engagingOk are we looking 1" exactly or is there a tolerance
Turboflash
- Mar 18, 2019
- Southern MN
My 2017 Cat has the Team primary w center needle bearing. Must have been 1st year? Don't know for sure.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Yea I thought it was 2018 not 4sure on that. It really is an innovative idea that should make for butter smooth engagement and reverse actuator should last longer 4 sure.My 2017 Cat has the Team primary w center needle bearing. Must have been 1st year? Don't know for sure.
Turboflash
- Mar 18, 2019
- Southern MN
Yes, very smooth when engaging and shifting for sure. No issues at all. All will be good until that center needle bearing fails. These clutches were recalled and replaced by Cat in early 2018 for some problem related to that bearing. So far so good. Mine's only got about 3000 miles on it. Bearing still sounds quiet.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
That's Johnie Klim Yellow Pants right there boys
Looks like he’s having issues with the spare belt? It’s a ski-doo with low miles obviously.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Not a new idea. Same method was used on golf carts for years. Cool idea nevertheless.
I've seen it on some very old sleds also, maybe Johnson? Can't remember for sure.Not a new idea. Same method was used on golf carts for years. Cool idea nevertheless.
Arc21981
- Jan 31, 2019
- Portland,Maine
- 2018 Sidewinder xtx se 137"
I think most ATV'S and UTV'S have been doing it for quite some time as well. I know my 2005 Kawasaki has one way bearing on clutch and so did Can-am back then too.
4strokes
- Mar 13, 2018
- charlemont ma
- 18 winder xtx 09 nytro xtx 06 apex gt
yes, many carts and atv etc use them, alot of them are one way, they call it engine breaking. I have had to shim many secondaries because the drag was too much to shift or would creep even with the bearing. yamaha ultramatic uses a wet clutch/with one way bearing. best set up I have ever seen. would like to see something similar on the sleds. possibly even an automotive style cvt, with controlled/programmed shifting.
- 13K
