Murse
- Sep 7, 2012
- Cornwall, Ontario, Canada
- 2011 Yamaha Apex Std Red
As Stated above. I have a low speed belt whistle need to clean clutches can I use brake cleaner or should I use something else?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
No don't not use brake cleaner, use Dawn Dish soap and hot water.
Murse
- Sep 7, 2012
ok thank you!
ualav8
Why not?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Because it has petroleum products in it which the metal will absorb it and cause the belt to slip.
ualav8
seems like it would be the perfect product to use. It takes petroleum products off of brake rotors and leaves a clean dry surface so the pads don't slip.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Brake cleaner is a degreaser! Everywhere I looked they say it leaves no residue. I know a huge amount of people including myself that have used it. I mean if it had anything to make the clutch slip what about the brakes? Now carb cleaner is not a good idea most leave a oil residue behind!
Guess you read the label to see if it has petroleum products but the stuff I've used says it leaves no residue and I've had no problem with it. I'm all in favor of dawn and water especially in the dishwasher. Have an old dishwasher that I would love to set up in the garage if I get it heated.
black knight
i have used brake cleaner on my clutch faces for years. leaves them squeeky clean.
brake cleaner on rag then wipe.
not sure i want to pump it into the areas that have plastic. Break clean can really dry stuff out.
My 2 cents
My 2 cents
chris189
- Nov 27, 2011
- Hanover Ontario
- 2007 Apex GT, 1980 Enticer 340
If you are worried after than use a semi aggressive 3m pad.
icebreaker
- Aug 18, 2010
- Southern wisconsin
- 2011 xtx
Brake cleaner, carb cleaner it all works no issues here for years. Just wipe the sheaves with acetone when ready to put belt on.
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
You can use it on the sheaves but acetone also works. We used acetone on clutch sheaves when I used to pit for a guy in the old Mid America Ice Drag Racing circuit. He made the podium a few times so I believe it worked well.
Sasquatch
- Apr 17, 2004
- www.dptc.com
- Yamaha's
You can use it on the sheaves but acetone also works. We used acetone on clutch sheaves when I used to pit for a guy in the old Mid America Ice Drag Racing circuit. He made the podium a few times so I believe it worked well.![]()
Yep acetone works but use gloves that won't melt and keep it off your skin. Very bad stuff! Well ventilated area fumes are hazardous!
