rnusr01
- Nov 6, 2016
- CT
- 2021 MXZ-XRS 850
Hi Guys
So I have both primary and secondary clutches off. The secondary dismantled to install new spring and rollers. While its apart I wanted to clean everything before assembly here are my questions.
1. I am assuming brake cleaner is fine to use?
2. Should I use a scrotch brite or anything to smooth/clean/polish where the belt rides?
3. Should I put a small amount of grease where the shaft goes?
4. Any tips tricks things I should be aware of?
Thank you
Thank you
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
How did you pull the primary off?
Green scotchbrite & acetone is what I've always used.
rnusr01
- Nov 6, 2016
- CT
- 2021 MXZ-XRS 850
Clutch puller tool it was easy
krm
- Apr 22, 2016
- ny
Don't use grease on anything in the clutches .
rnusr01
- Nov 6, 2016
- CT
- 2021 MXZ-XRS 850
I meant on the splined shaft the secondary goes on should that have a small amount of grease ?
I do because it rusts otherwise. Anti Sieze.I meant on the splined shaft the secondary goes on should that have a small amount of grease ?
rnusr01
- Nov 6, 2016
- CT
- 2021 MXZ-XRS 850
Doc Harley
- Oct 17, 2016
- Here & there
Where did you get it?
EPI makes a good oneWhere did you get it?
rnusr01
- Nov 6, 2016
- CT
- 2021 MXZ-XRS 850
Doc Harley
- Oct 17, 2016
- Here & there
On order......thanks guys.
silverram323
- Mar 24, 2013
- Jodrell St, Cambridge, mn 55008
- beyondsynthetics.net
- 2017 Sidewinder XT-X 141
I have the same one, works great.
- 11K
