Can power steering be added?
2006Apexed
Wisconsin
2006 Apex RTX
I have an 06 Apex without power steering. Can power steering be added (cost effectively) from a salvage sled?
You have to change the tank and maybe the the front spinals to.
I have never done it but if you want easysteering put snowtrackers on.
I had two 06 apexs sleds and that was the fix for darting and heavy steering.
Thanks, that sounds way more easy and less expensive. Do you have a link to where I can purchase them?
I also offer a mechanical power steering kit (MPS). I distribute snowtrackers too. Both will reduce your steering effort.
Contact Travis, he will hook you up with MPS, the best most inexpensive way to achieve this.
mrsled did add eps to a venture that did not have it a few years ago.
I ordered a pair of Snowtrackers. I will see if they deliver the desired results. Thanks for the lead.
I run Snowtrackers and when I jump on a EPS machine I don't even notice the power assist. This is how well they work to lighten the steering when moving.
I now have Travis' (Barn of Parts) MPS kit on my 08 LTX and his kit works well too when coming off my 18 XTX with EPS.
