HydrogenCyanide
- Oct 21, 2020
- Fort Erie
- 2006 Yamaha RS Nytro
2006 Yamaha Apex
I have noticed after riding my sled is getting warm and loosing coolant. Put sled on lift today to try to figure out. This is a 2014 Viper. I can't see where the coolant is leaking from but for the life of my I cannot figure where exactly the leak is. Its dripping from directly under the clutch but not from any of the connectors. Any ideas. All of the visible clamps appear to be tight and I do not see anything leaking from there either. It seems to be coming directly from the bottom.
Please see video of leak. Any ideas? I am at a loss...
I had one last month leaking in this general area and it was one of the welds cracking on the heat exchanger. We removed and changed out with a good used one.
HydrogenCyanide
- Oct 21, 2020
- Fort Erie
2006 Yamaha Apex
How big of a job was this? What needs to be removed from the sled to be able to change the heat exchanger. I have a feeling it could be coming from one of the welds as well.I had one last month leaking in this general area and it was one of the welds cracking on the heat exchanger. We removed and changed out with a good used one.
DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
Common problem on these Vipers. My brother just had his start leaking on our last trip for the second time in the past 3 years. Dealer repaired both times. First one he was still under warranty....thankfully.
Yes, big job. A lot has to come apart.
I would use the Yamaha Japan rivets when replacing instead of the lower quality Cat rivets.
DennyTuna
- Jan 28, 2017
- Ohio
Doing a track change on my nephews 14, tore it apart last week, it hung all week waiting for new track, arrive yesterday morning to install new track only to find coolant on the floor where these heat exchangers like to crack. Sure enough, cracked on that weld. The hardest part now is finding one...back ordered.I had one last month leaking in this general area and it was one of the welds cracking on the heat exchanger. We removed and changed out with a good used one.
HydrogenCyanide
- Oct 21, 2020
- Fort Erie
2006 Yamaha Apex
I brought it into a shop and they are saying it is the heat exchanger. They've quoted me $1470 USD to change out the heat exchanger. Does this seem right?
Also, anyone know of a guide on how to do this if I were to attempt to tackle myself?
DennyTuna
- Jan 28, 2017
- Ohio
I don't think so, my brother paid $1800. but had both clutch side bearings replaced and some welding on the header for that price. If you become a VIP member TY will send you a PDF of the service manual for your sled. That will help you out some. It's a big job. Just bought the heat exchanger from Port Yamaha for my nephew, it was like $348. plus rivets, tax and shipping.They've quoted me $1470 USD
captainruss99
- Feb 17, 2019
- lewiston maine
- 2016 eltigre 7000
I too had a exchanger leaking on my 16 7000. It was leaking on the top left corner, on the track side. Not where it was welded, but it was cracked ever so slightly. Cat had them back ordered, I found a Yamaha one through Partzilla for a very good price. Also bought the Yamaha rivets. It's quite a job. I did it in different days, as I was waiting for the UPS man to bring it to me. You would be hard pressed to get it done in less than 10 hours. Seat, tank, exhaust pipe, inner and outer chain case, skid frame, both shafts, caliper, rotor. Have to prop up the engine, as the rear motor mounts bolt into the exchanger. Be gentle lining them back up. Better have an air riveter, angle drill, lots of patience
captainruss99
- Feb 17, 2019
- lewiston maine
- 2016 eltigre 7000
I just watched hydrogens video, exactly where mine was dripping from, and only at 140 degrees and up. under that temp, it wouldn't leak.
Froggy
- Apr 29, 2016
- Kipawa,Quebec
- 2020 Winder LTX SE 14600 km and counting
2016 Viper LTX LE 23986 km sold
2015 Viper LTX DX Wife's 19500 km
2010 Vector LTX GT 25000 km sold
Watch that pipe behind the primary clutch that comes from the heat exchanger and up to the rad, I had 2 Vipers that the pipe was rubbing on the frame and were almost worn right through.
