Can't find a bolt replacement
yamaha247365
Wisconsin
09' FX Nytro
So I took off my nose cone and had to drill out the phillips head screw/bolt. I need to replace them. I found the same bolt on the rear side plastics with a 10mm head. I would rather have the bolt head but I can't find where to buy them. Fastenal could not find anything close. Any suggestions?
How far to your dealer? Or a metric bolt with a series of washers or a piece of metal tube and a washer. I just moved my tailight and the bracket has those bolts too,
Next time you take that bolt out put a small amount of valve grinding compound on the screw driver .
Well that won't help me now but I don't know that trick. Does the compound give the driver more grip?
P/N is 90149-06263-00 for 1 each
Pete
Pete
Thank you. By chance do you have the number for the bolt in the picture? I believe it holds down the tail light and hold the side plastics to the aliminum exhaust shroud.
Yup thats the bolt that holds on the plastic side panel under seat.
Pete
Tailight bolt 90109-06043-00
If the bolt has 10 mm head, chances are it's an M6 x 1, unless it's a screw that threads into plastic?
Your local hardware should stock this diameter and thread pitch, it's very common. All you need is to determine the length needed.
