The tank comes from a SDI-model, so i have used the original SDI-pump. I have just made the same holes for the sender unit as the RX1-tank has.
Sportsterdanne
No leaks from the sender unit hole ?
how did you attach the bolts on the inside ?
I have no problem with leaks, but i used silicon that stands fuel when i mounted it. For the bolts i used threads that looks like a rivet(popnit in Swedish..)
givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
I've been building my midmount setup and have a different idea for the oil drain. I don't like the idea of the drain into the engine at only about 3'' drop. When you're climbing a long steep hill the drain will be higher than the bottom of the turbo . So where's that oil going to go ? I welded a aluminum tube 3'' lower than the timing plug to give it a little extra fall. With this setup the drain line runs downhill the whole way.capri said:I have not been here for long, but thank you for the pics Red!. I have copied your drain line, and it works great!
Ken.....
- 28K
- 19K
- 10K
