dntmndr
97 xtc 600 landed in my garage wouldn't start.. no big deal, carbs plugged with belt dust and some debris cleaned the carbs now it starts but runs like it running out of gas has a lean bachfire at idle. idles good with the choke on full . recheck pilot jets and choke circut no visual problem found. sled will power brake and seems to run good under load.it will idle if the rpm is above or at 3000..... what am i over looking
duhr8m
- Oct 27, 2007
- Minocqua WI
- sidewinder, SRXs, snow scoot + sport, vmaxs, enticers
not sure but if it has reeds check for bunt off or broken plates. will make it pop
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
You made sure you could blow/see through the pilot jets? Just making sure you took them out of the carbs to clean.
dntmndr
the pilot jets are clean as a wistle and all the reed petals are there ,didn't remove them but looked at them my next step i think is to tank the carb bodies ???
dntmndr
hey thanks for the ideas two year old gas no stabill, some people take good care of the toys....
Crewchief47
- Jan 16, 2006
I see, the old rotten fuel trick, gotta love it!
- 18K
- 6K
