livinloud
ok just a quick questiong guys i am about to replace my carbides i have ATS arrow skis double runner and i have 2 options 5" 90degrees or 6" 60degrees. what should i get? the sled has 96studs and doesnt turn for s**t. it pushes through the corners like crazy the carbides on there now are done there is nothing left
rxscot
I think your going to be about equal on those. 90 is sharper and shorter, 60 is longer and not as sharp.
Personally I always go for 90 as long as possible doolies. But in your case anything is better than the flat steel you have now.
livinloud
i would really like to get somthing longer than 5 inches how can i outsource this?
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
rxscot said:I think your going to be about equal on those. 90 is sharper and shorter, 60 is longer and not as sharp.
Actually 60's are sharper than 90's.
Smaller angle = sharper and more bite.
livinloud
so i am wondering if the 90degree 5inch will be good for me they are definatly the cheaper solution at only 100buks for 4 carbides
- 14K
