Albanyco
- Jan 1, 2020
- Albany, new york
- Attak
Just an update, I ended up going with a 6 inch carbide on the inside and a 4 inch carbide on the outside. Both from woodys. I did consider snow trackers, but I tend to have to cross a lot of roads and train tracks and I was concerned about the skis getting hung up. I’m looking forward to getting out and riding this season with fresh carbides!
Wannaviper
- Mar 18, 2014
- West Gardiner, Maine
Hopefully they will work for you; I used that set up on my first Viper for a very short time before switching over to Cat skis and Snow Trackers. I have heard people voice their concerns about crossing railroad tracks and roads with the Snow Trackers, but I have had Trackers on Yamaha skis, Cat skis, and Tuners, and over many thousand miles, have never had a problem. I was one of the ones who resisted switching to Trackers out of concern about that much metal under the ski, but my fears were unfounded, and I have been very happy with my Trackers.Just an update, I ended up going with a 6 inch carbide on the inside and a 4 inch carbide on the outside. Both from woodys. I did consider snow trackers, but I tend to have to cross a lot of roads and train tracks and I was concerned about the skis getting hung up. I’m looking forward to getting out and riding this season with fresh carbides!
ThatOneGuy'sBrother
- Oct 12, 2014
- Monroe County Norwalk WI
- 2020 Sidewinder LTX GT 2015 Apex XTX
If you are going to keep your Tuners, depending upon your budget for carbides, Snow Trackers makes carbides for the Tuners. I really do not like anything about the Tuner skis, and have replaced them on all my sleds except the most recent one, a Sidewinder LTX. Because I had a big trip coming up at the time I bought the sled, I did not have time to swap out the Tuners, so I took a chance on the Snow Trackers. That was over 5,000 miles ago, and the Tracker/Tuner skis are still on my sled. If you are a trail rider, forget all the expensive aftermarket skis with all the bells and whistles to stop push and prevent darting, etc. The Tracker/Tuner combo is easy to steer, with no darting, and they have little or no push under most conditions. The 5,000+ miles I have on my Sidewinder have been the most enjoyable miles I have ever had on a snowmobile, and I don't want to change a thing.
On the DB chassis the tuners worked great for me trail riding! I always got the biggest carbide and the largest square bar. Did this on our apex and 15 phazer. They both worked great.
With our 2020 winder i also purchased snow trackers. I have not rode it yet. Travis at BOP seems to have sold a pile of them. Lighter laser sharp steering is what everyone has told me. Great for trail riding and not good off trail. Will see this winter how well they work for us!!!
CaptCaper
- Jan 1, 2007
- Northern N.H.
OP I see your strapped for cash. I have the Woody's carbides in 6in on both inside and outside. Steers fine for my riding. I ride at least 1500 10 2000 miles a year for 16 yrs now on Yamaha Apex,Vectors of different styles and find the Tuners are fine for my trail riding in NH with many different conditions and no need to spend big bucks on other ski's.
Wannaviper
- Mar 18, 2014
Tuner skis were developed specifically for the DB chassis of the Vectors and Apexes, and by most reports, they worked well there. Tuners were not designed for the Pro-Cross chassis, and they simply do not work well with it. There is a reason that Yamaha finally stopped putting Tuners on the Vipers and Sidewinders this year!
srvfan
- Nov 9, 2004
For those with the trackers and tuners : I just bought them for my 16 viper 129. Did you crank up the center spring to 75% like snow tracker says ??? Seems like a lot. Currently I’m running that spring almost full loose with the single keel Kimpex skis I have on there I’m going back to the Tuner FYI don’t buy the Kimpex highly disappointing Kimpex arrows
YamahaHoss
- Mar 23, 2020
- Wisconsin
- Yamaha RS Venture
Hi, If I stay with my Tuner skis on myb15 RS Vebture TF, what crabides would you reccomend? (I would like to not use Snowtrackers. ) Also , I have used two 6 inch Woody Ace high profile thenlast two years, and they are pretty good, but should I I atrad have a 4 inch on the inside and the 6 inch on the outside? (OR vice versa?) OR would two 4 inch one be better for less darting??I used the 6 inch carbide Woddys Ace Bar on the inside with the stock 4 inch carbide round bar on the outside. It work pretty good but when the trails warm up and get a little mushy they will push when running hard but when things are frozen up it will be on rails with no push or darting what so ever. I have messed around with ski's and found the Cat ski with the staggered carbide or snow trackers work the best. You will get a bunch of different opinions on this but that's what I found works the best with out buying aftermarket ski's.
ThatOneGuy'sBrother
- Oct 12, 2014
I have always used the same carbides inside and outside except on my wife's 15 phazer xtx. That one I did experiment with different sizes on its tuner skis. If you are wanting to reduce darting and do not ride that hard I would probably go with just 4 inch carbides and a small profile bar. I would do this on both sides. On warm days tuner skis like to push in the corners. That's why we go with the biggest profile bars. If you don't ride hard a I would think a smaller bar would push more but have less darting. Less bar to hook other people's tracks would be my theory. If you have studs in the track it will be harder to turn. Then you may want the large bars and as much carbide as you can. Those heavy long tracks do not like to turn as it is. Especially with a rider. If you have studs they will only like to go straight.
- 7K
