rxwhopper
need to replace mine, where is the best place. the ones that came with mine was a actic cat package
http://www.bergstromskegs.com/
Scott Bergstrom's skegs are some of the best carbides out there. I use the tripple points on the inside of my Simmons skis.
rxwhopper
also some shims for the skis
Call Scott, he will take care of you with free shims and advice on what type and size of carbides you will need for your sled and riding style.
LazyBastard
Scott'll throw in the shims, BUT, depending on your application, customizing the shims may be necessary. What you need to know about the shims is that all they are is a piece of plastic that is shoved between the rubber and the saddle BEHIND the bolt. This forces the back of the ski down, allowing the ski to lift up out of ruts to prevent darting and decrease steering effort.
