Chain case adjustment
hognit09
beaver dam, wi.
2016 viper ltx le,2016 viper ltx dx
After adjusting chain case for first time,wow what a pain in the a** to get the spring back on. I'm thinking I would like to install an aftermarket muffler next time I pull this apart, but I would be looking for the quietest or closest to stock muffler. With the d&d, Straightline/ulmers, or slp would I be able to still adjust chain without removing? On another note, I have never seen so many rough edges or burrs on everything, I cut myself 3 times doing this
put staightline can on very quiet and can adjust chain without removing
I have a D&D and can adjust. A little louder at idle, other than that it is pretty quiet
As for the spring, take a piece of #9 wire, or about 1/8"x 12" to 15". Bend a small hook in one end and a handle in the other , leave the spring hanging from it's bottom hole. then when muffler is in place reach in with your new tool, hook the other end and hook it up. A piece of cake.
To keep from damaging the gasket is the hand part.
pulling the muffler would even be ok if i had better access to the spring.thats the hardest part
i ended putting a zip tie to hold spring up while i installed muffler and then attached it. first time, just took a little redneck inginuity. think i spelled that wrong
This is what I use. It's a spring tool for headlights.
X2 Just barely attach the two ends of a zip tie to make a loop and you got yourself a handle to pull the spring up and into place. Cheap and easy!
