rkkoeb
- Aug 30, 2019
- Green Bay
- None right now
09 apex while racing my buddy today my chain broken in my chain case. Looking for suggestions
- I went down one tooth on the top sprocket, should I stay with the stock length chain of 70L or go smaller
- What brand should I buy
- How much oil does the chain case take
- What weight oil should I get
rkkoeb
- Aug 30, 2019
- Green Bay
- None right now
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Yamaha OEM 70 link chain, 8.5 oz Yamalube chain case oil.
rkkoeb
- Aug 30, 2019
- Green Bay
- None right now
so you think I should stay with the stock 70 link chain and not go down to a 68 even though I did drop down one tooth on top gear?
rkkoeb
- Aug 30, 2019
- Green Bay
- None right now
any other suggestions then the Yamalube for the chain case? I don't have a deal really that close to me
How many teeth is your top sprocket?
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Amsoil chain case lube. I swear by it.any other suggestions then the Yamalube for the chain case? I don't have a deal really that close to me
mryamaha
Man that thing looks dry.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
I had to switch to 75/140 gear lube to keep my chain stretching every other year on my boosted apex. I would run any 75/90 fluid that is local. The OEM chain is the most durable, they are a wear item.
rkkoeb
- Aug 30, 2019
- Green Bay
- None right now
I not sure what tooth I am running, all I know is I am one smaller than stock.
When I open the chain case it had plenty of oil in it so it was not dry
I will stay with the OEM chain but just wanted to check and see if I should stay with the 70 or if I can go down to a 68
Thanks for the help
Thanks for the help
rkkoeb
- Aug 30, 2019
- Green Bay
- None right now
One thing I did notice was when I drain the oil before taking the cover off it was a darkish grey in color and was just changed at the end of last year. Not sure what caused this or if that happen after the chain broke. Found a bunch of little chain piece on the bottom of the chain case when I took the chain out
any 80w90 or 75w90 gear lube will work fine. stay with the 70l. i change my oil annually as well but i did rebearing my 11 around the 12000 mi mark after my rx lost a cage on one of the chain case bearings around the same milage. did the gears and chain at the same time. how many miles on the sled when it let go?
rkkoeb
- Aug 30, 2019
- Green Bay
- None right now
7000 miles. Just did all new bearing as I did a track extension from 121 to 136. Is there a difference between gear oil and chain oil
not really. i personally use royal purple 75w140 in all my sleds or good synthetic gear lube.
