DJ Hennessy
- Jan 30, 2016
- Barrie, ON
- 2016 Yamaha Viper RTX SE
2006 Yamaha Apex RTX
2006 Apex, I've torn this thing apart a few times now and drawing a blank on this... I forgot to tighten the nut on the tension bolt for the chain and took it out for a ride, 30kms in... Worst sound ever and had to get picked up by the rescue trailer! Realized what I did, but because I had to limp it back to a road, I'm noticing some serious grooves I think I wore into the forward gear. Put it all back together tonight and went to put into reverse and it moved maybe an 1nch... I didn't even try forward because I didn't want to screw it up more. Wondering if maybe I now had the tension on the chain too tight? Also, just to make sure I'm doing it right, the forks on the reverse arms are to drop into the gear slot right? Not from the bottom...
I'm thinking with the grooves in the forward gear I should likely replace it, worried that the if I get this thing moving again, the chain could just slip a tooth possibly???
Turn the secondary by hand to engage in forward. You will feel or hear bad things if its screwed. Chain tension should be finger tight then back off 1/2 a turn.
There is an obvious groove in the gear were the shift fork slides into.
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
x2 with Steiner.
The shift fork engages the groove (red arrow) as the outer chaincase cover slides on.
snowbiscuit
Its very common for reverse linkage to be out of adjustment when working on chaincase on the older Apexs and will lockup like you mentioned in reverse. Put it in forward and get back end up so you can turn secondary by hand. Good chance it will be free and all that's needed is a reverse linkage adj
Apex1958
- Feb 26, 2009
- Rotterdam, NY
- 06 Apex, 16 APEX LE
Back off 1/4 turn NOT 1/2
DJ Hennessy
- Jan 30, 2016
- Barrie, ON
The groove I knew about, just thought maybe I was dropping the forks in wrong into it, turns out all was good. Too tight on the tensioner I think, got it moving tonight on the lift by turning by hand like steiner said and then turn it on to try with throttle. Was smooth in forward movement and then reverse, but when I went back to forward it made a pretty good snap sound... Thinking the wear on the forward sprocket from the chain being so loose while trying to get it off the trail allowed some slack in the chain. Have ordered a new forward sprocket since the old one looks like it has almost serrated teeth on it, and hoping the chain will be all good and not weakened at all by this. Can't see how the linkage would've moved though???
DJ Hennessy
- Jan 30, 2016
- Barrie, ON
If I need it to pull the out more, would I spread the linkage further or tighter?Its very common for reverse linkage to be out of adjustment when working on chaincase on the older Apexs and will lockup like you mentioned in reverse. Put it in forward and get back end up so you can turn secondary by hand. Good chance it will be free and all that's needed is a reverse linkage adj
snowbiscuit
Its been a while since making adjustment....this should help http://ty4stroke.com/threads/apex-chaincase-reverse.80183/
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
When I purchased my 09 apex last March with only 2k miles on it, at times it would grind backing up with a load on it (ie slight incline). I did a very minor adjustment to the linkage following the manual and all is good now.
- 18K
