Nodak
- Jan 9, 2024
- North Dakota
- 05 Yamaha rs venture
So I had a spill of chain case lube when filling the case. Not sure how much I spelt. Where should it be on the dip stick?should it be between the arrows? Or should I drain it all and start over
It should have more to the lines at STD but flip it over and the other side should be labeled for reverse.
Nodak
- Jan 9, 2024
- North Dakota
what does the reverse side mean? And should it go in between the arrows on the std. side?It should have more to the lines at STD but flip it over and the other side should be labeled for reverse.
RobX-1
- Coldwater, OH
Nodak
- Jan 9, 2024
- North Dakota
So since I have reverse I look at the reverse side and not the standard side?
CorrectSo since I have reverse I look at the reverse side and not the standard side?
RobX-1
- Coldwater, OH
Athough I do have reverse, when servicing the chain case I just always add 8.5oz of Yamaha's full synthetic chain case lube which does push the oil level a little higher on the dip stick for reverse but never has been a problem.
Nodak
- Jan 9, 2024
- North Dakota
Awesome thanks guys. So does one with reverse take less oil than one without reverse? Just seems that way looking at the dipstick. Or is it just the way the dipstick sits in the chain case
There is a lot more stuff to displace the oil.
Fast Lane
- Feb 6, 2020
- Winnipeg
- 2007 Yamaha Nytro ER
- Winnipeg
I go over the reverse max side and never had an issue. I'm sure there is a reason why they have the max at a lower side but sometimes its hard to hit the line spot on. Next morning I find Ive gone over.
Over is not a big deal!I go over the reverse max side and never had an issue. I'm sure there is a reason why they have the max at a lower side but sometimes it’s hard to hit the line spot on. Next morning I find Ive gone over.
Nodak
- Jan 9, 2024
- North Dakota
So I would guess I got about 6 oz in. It right at the R on the dipstick for the reverse side. Should I let it rock?
Let it rock!!So I would guess I got about 6 oz in. It right at the R on the dipstick for the reverse side. Should I let it rock?
Nodak
- Jan 9, 2024
- North Dakota
Thanks! I really appreciate everyone’s help
