Super Sled
- Feb 25, 2009
- Summit X
Hey Lawman, I read you first post. My rec to you is gear lube. Your welcome. Now will you stop being so crabby in your posts please?
Gearlube only ,trans fluid for racing.
lawmanbsi
Super Sled said:Hey Lawman, I read you first post. My rec to you is gear lube. Your welcome. Now will you stop being so crabby in your posts please?
not crabby just pokin.
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
i've always run amsoil atf in my chaincases - i started with my viper and have run it in my phazers along with my sons nytros. i figure they recommend atf in transfer cases so it's good enough for the sled - no gear to gear contact plus the chain so atf is my choice.
LJ 452
Good point, 4x4 transfer cases are very similar to a sled chain case. In fact most use the same type of chain. Only difference may be the speeds of the internals. Stock requirement for the transfer case is ATF, some shops are recommending a new Amsoil tractor oil for Duramax cases. like I said, anything may work but I've just stuck with what worked for me, I also think that changing it out frequently helps and the shearing forces probably break it down quickly. Just cause it may be clean doesn't mean it's working.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
LJ 452 said:Good point, 4x4 transfer cases are very similar to a sled chain case. In fact most use the same type of chain. Only difference may be the speeds of the internals. Stock requirement for the transfer case is ATF, some shops are recommending a new Amsoil tractor oil for Duramax cases. like I said, anything may work but I've just stuck with what worked for me, I also think that changing it out frequently helps and the shearing forces probably break it down quickly. Just cause it may be clean doesn't mean it's working.
A big mistake a lot of folks make, with a lot of oils/lubes!
Personally, if I find oils/lubes that are not dirty, then I question the cleaning capabilities of them, which usually makes me discontinue their use!
Rich Kay
- Mar 29, 2006
- SE MI. Howell
- Yamaha apex rtx
Amsoil chain case lube in all my sleds (chaincase) plus almost everyone I ride with. Waay!! too many miles to add up and 0 problems! Infact I don't beleive I can say we have ever had any chaincase problems. I have changed driveshaft bearings and upon opening the chaincase up can't beleive how well the chain and gears look.....some sleds with over 10,000 miles! Now I hope I didn't "jinks" myself!
Rich Kay.
Rich Kay.
Super Sled
- Feb 25, 2009
- Summit X
Irv said:Personally, if I find oils/lubes that are not dirty, then I question the cleaning capabilities of them, which usually makes me discontinue their use!
Excellent observation!!!!!
woolyviper
- Mar 24, 2006
- hibbing,mn
plus it's red - and i like red.
my son had an 8500 mile AC, i had a 5000 mile phazer and my son had a 7000 mile nytro that all looked good running the atf. i think anything would work just as long you keep it clean.
lawmanbsi
If i go with the atf how much should I put in?
How many miles before a change?
I have had older sleds myself and thats all we ran in the chaincase was atf with 0 problems. If you changed it twice a season I think that would be plenty. ATF is pretty tuff oil look what it goes through in a transmission.
