FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
2026 EXT858 Special
- YOUTUBE
- FrozenTows1
2014 XF7000....after evacuating the chain case oil, appears I added too much. Manual says 12oz Yamalube. Bottles come in 8oz. Added less than 1 1/2 bottles while watching the sight glass to about 3/4 full. Less than 30 seconds later, it was past the sight glass.
Will being over full make a mess, or cause damage, down the road?
Top of the site glass will not be a problem. The oil is think and it takes time to settle. If you put in the spec amount I would not be concerned.
Tilt the sled to see you probably are real close.
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
2026 EXT858 Special
- YOUTUBE
- FrozenTows1
Perfect! Will tip a little, to double check, tonight. Final check before tucking them in for the summer.
Sean80
- Oct 14, 2015
- 99 Vmax 700
Mine was at top of the sight glass the entire past season and I didn't have an issue. Makes it easier to ensure you have fluid in my opinion.
Sent from my SM-G920W8 using Tapatalk
Yes I also run mine right at top and a little more. Try to help that top gear bushing last longer.
