chain size
dd 14
ontario
Can someone please tell me will the stock chain in a 06 rtx work for a 23 tooth gear or do i need a different chain tryed to search it but got a dozen pages with everything on gears but the chain size
thanks to any help
No need to change the chain with 23/38 gear.you can keep the 70 link chain.lower gear like 22/38 need a shorter chain...68 link.
SharkAttak said:
do you need to change the chain if you go with the 40t bottom or is it long enough for the attak
No need to change the chain for 23/40 gear,you can keep the 70 link chain.
